XBTZGPWS1
XBTZGPWS1
Share Send by e-mail power supply connector for advanced panel Support
Part Number xbtzgpws1_xbt_gc
Accessory / Separate Part Category Connection accessories
Accessory / Separate Part Designation Power supply connector
Accessory / Separate Part Destination Advanced panel3.5" small touch screen panel
Accessory / Separate Part Type Power supply connector
Acquisition Period No
Additional Information No
Ambient Air Temperature For Op No
Ambient Air Temperature For St No
Analogue Input Number No
Analogue Input Resolution No
Analogue Output Number No
Analogue Output Resolution No
Analogue Output Type No
Awg Gauge No
Backlight Lifespan No
Brightness No
Bus Type No
Cable Cross Section No
Cable Function No
Cable Length No
Category Detail 22569 - MAGELIS XBT-GT (AND XBT-G)
Character Font No
Color No
Company Schneider Electric
Connections Terminals No
Connector Destination No
Connector Type No
Contrast No
Conversion Time No
Country Of Origin JP
Current Per Channel No
Current Per Output Common No
Current State 0 Guaranteed No
Current State 1 Guaranteed No
Cut-Out Dimensions No
Dielectric Strength No
Discrete Input Current No
Discrete Input Logic No
Discrete Input Number No
Discrete Input Voltage No
Discrete Input Voltage Type No
Discrete Output Current No
Discrete Output Function No
Discrete Output Logic No
Discrete Output Number No
Discrete Output Type No
Discrete Output Voltage No
Discrete Output Voltage Type No
Display Colour No
Display Resolution No
Display Size No
Display Type No
Downloadable Protocols No
Electrical Connection No
Electrical Durability No
Fixing Mode No
GTIN 785901512981
I/O Expansion Capacity No
Input Voltage Limits No
Insulation Between Channel And No
Integrated Connection Type No
IP Degree Of Protection No
Isolation Between Channels No
Isolation Between Channels And No
Isolation Between Input Channe No
Isolation Between Output Chann No
Kit Composition No
Leakage Current No
Line Rated Current No
Load Impedance Ohmic No
Load Type No
Local Signalling No
Lsb Value No
Marking No
Mechanical Durability No
Memory Description No
Memory Type No
Minimum Switching Current No
Mounting Support No
Nbr. of units in pkg. 1
NEMA Degree Of Protection No
Non Linearity No
Number Of Alphanumeric Keys No
Number Of Channels No
Number Of Common Point No
Number Of Contacts No
Number Of Dynamic Function Key No
Number Of Modules Per Base Con No
Number Of Pages No
Number Of Service Keys No
Number Of Static Function Keys No
Number Of Terminal Per Channel No
Operating System No
Output Error No
Output Voltage Limits No
Overload Protection No
Overvoltage Category No
Permissible Continuous Overloa No
Pin Number No
Pixel Resolution No
Polarity Distribution No
Pollution Degree No
Port Ethernet No
Power Consumption No
Power Dissipation In W No
Processor Frequency No
Processor Name No
Product Availability Stock - Normally stocked in distribution facility
Product Certifications No
Product Compatibility XBTGK2.XBTGT1.XBTGT2.XBTGT4.HMISTU
Product End Of Life Instructio Available
Product Life Status No
Product Mounting No
Product Or Component Type No
Product Specific Application No
Product Weight No
Repeat Accuracy No
Resistance To Electromagnetic No
Resistance To Electrostatic Di No
Resistance To Fast Transients No
Resistance To Incandescent Wir No
Resistance To Radiated Fields No
Response Time No
Returnability N
RoHS (date code: YYWW) Compliant  - since  0703  -  Schneider Electric declaration of conformity
Shock Resistance No
Short Circuit Protection No
Stabilisation Time No
Status Led No
Supply Voltage Limits No
Switched Current No
Switching Frequency No
Temperature Coefficient No
Terminal Block Type No
Terminator Resistance No
Tightening Torque No
Total Error No
Total Number Of Wires No
Touch Panel No
Touch Sensitive Zone No
Transmission Rate No
Type Of Cable No
Ue Rated Operational Voltage No
Ui Rated Insulation Voltage No
Uimp Rated Impulse Withstand No
[US] Rated Supply Voltage No
Use Of Slot No
Vibration Resistance No
Voltage Drop On Power Supply F No
Voltage State1 Guaranteed No
Voltage State 0 Guaranteed No
Warranty Period 18 months
Analogue Input Type No
Current Consumption No
Depth No
Discount Schedule MC2
Enclosure Material No
Encoding Type No
Filter Time No
Fuse Curve No
Fuse Size No
Height No
Input Impedance No
Measurement Error No
Package Weight (Lbs) 1
Quantity Per Set No
Range Compatibility No
Range Of Product Magelis XBT
Reach No
Realtime Clock No
Relative Humidity No
Software Designation No
Software Type No
Standards No
Supply No
Sustainable Offer Status Green Premium product
Width No
Wire Section No
