XBTGT6330
XBTGT6330
Share Send by e-mail advanced touchscreen panel - 800 x 600 pixels SVGA - 12.1" - TFT LCD - 24 V DC Support
Part Number xbtgt6330_xbt_gc
Accessory / Separate Part Category No
Accessory / Separate Part Designation No
Accessory / Separate Part Destination No
Accessory / Separate Part Type No
Acquisition Period No
Additional Information No
Ambient Air Temperature For Op 32...122 °F (0...50 °C)
Ambient Air Temperature For St -4...140 °F (-20...60 °C)
Analogue Input Number No
Analogue Input Resolution No
Analogue Output Number No
Analogue Output Resolution No
Analogue Output Type No
Awg Gauge No
Backlight Lifespan No
Brightness 8 levels via touch panel
Bus Type No
Cable Cross Section No
Cable Function No
Cable Length No
Category Detail 22569 - MAGELIS XBT-GT (AND XBT-G)
Character Font ASCII (European characters)Chinese (simplified Chinese)Japanese (ANK, Kanji)KoreanTaiwanese (traditional Chinese)
Color No
Company Schneider Electric
Connections Terminals No
Connector Destination No
Connector Type No
Contrast No
Conversion Time No
Country Of Origin CN
Current Per Channel No
Current Per Output Common No
Current State 0 Guaranteed No
Current State 1 Guaranteed No
Cut-Out Dimensions 301.5 (+ 1/- 0) x 227.5 (+ 1/- 0) mm
Dielectric Strength No
Discrete Input Current No
Discrete Input Logic No
Discrete Input Number No
Discrete Input Voltage No
Discrete Input Voltage Type No
Discrete Output Current No
Discrete Output Function No
Discrete Output Logic No
Discrete Output Number No
Discrete Output Type No
Discrete Output Voltage No
Discrete Output Voltage Type No
Display Colour 65536 colours
Display Resolution 800 x 600 pixels SVGA
Display Size 12.1 inch
Display Type Backlit colour TFT LCD
Downloadable Protocols Modbus Telemecanique ModiconFIPWAY Telemecanique ModiconModbus Plus Telemecanique ModiconModbus TCP Telemecanique ModiconThird party protocols Mitsubishi MelsecThird party protocols Omron SysmacThird party protocols Siemens SimaticUni-TE Telemecanique Mod
Electrical Connection No
Electrical Durability No
Fixing Mode By 4 screw clampsBy 4 spring clips
GTIN 785901641810
I/O Expansion Capacity No
Input Voltage Limits No
Insulation Between Channel And No
Integrated Connection Type COM2 serial link RJ45 RS485
IP Degree Of Protection IP20 (rear panel) conforming to IEC 60529IP65 (front panel) conforming to IEC 60529
Isolation Between Channels No
Isolation Between Channels And No
Isolation Between Input Channe No
Isolation Between Output Chann No
Kit Composition No
Leakage Current No
Line Rated Current No
Load Impedance Ohmic No
Load Type No
Local Signalling 1 LED (green or orange) normal operation or backlighting faulty
Lsb Value No
Marking CE
Mechanical Durability No
Memory Description Back up of data SRAM 512 kB lithium battery
Memory Type 1 slot for Compact Flash card (128 MB to 1 GB)
Minimum Switching Current No
Mounting Support No
Nbr. of units in pkg. 1
NEMA Degree Of Protection NEMA 4X front panel (indoor use)
Non Linearity No
Number Of Alphanumeric Keys No
Number Of Channels No
Number Of Common Point No
Number Of Contacts No
Number Of Dynamic Function Key No
Number Of Modules Per Base Con No
Number Of Pages Limited by internal memory capacity
Number Of Service Keys No
Number Of Static Function Keys No
Number Of Terminal Per Channel No
Operating System Magelis
Output Error No
Output Voltage Limits No
Overload Protection No
Overvoltage Category No
Permissible Continuous Overloa No
Pin Number No
Pixel Resolution No
Polarity Distribution No
Pollution Degree No
Port Ethernet 10BASE-T/100BASE-TX
Power Consumption 30 W
Power Dissipation In W No
Processor Frequency 266 MHz
Processor Name CPU RISC
Product Availability Stock - Normally stocked in distribution facility
Product Certifications ATEX zone 2/22CSA Class 1 Division 2 T4ACSA Class 1 Division 2 T5C-TickcULusUL Class 1 Division 2 T4AUL Class 1 Division 2 T5
Product Compatibility No
Product End Of Life Instructio Available
Product Life Status End of Commercialization
Product Mounting Flush mounting
Product Or Component Type Advanced touchscreen panel
Product Specific Application No
Product Weight 6.61 lb(US) (3 kg)
Repeat Accuracy No
Resistance To Electromagnetic 9.14 V/yd (10 V/m) conforming to IEC 61000-4-3
Resistance To Electrostatic Di 6 kV IEC 61000-4-2 level 3
Resistance To Fast Transients 2 kV conforming to IEC 61000-4-4 level 3
Resistance To Incandescent Wir No
Resistance To Radiated Fields No
Response Time No
Returnability N
RoHS (date code: YYWW) Compliant  - since  0613  -  Schneider Electric declaration of conformity
Shock Resistance 15 gn 11 ms conforming to IEC 60068-2-27
Short Circuit Protection No
Stabilisation Time No
Status Led No
Supply Voltage Limits 19.2...28.8 V
Switched Current No
Switching Frequency No
Temperature Coefficient No
Terminal Block Type No
Terminator Resistance No
Tightening Torque No
Total Error No
Total Number Of Wires No
Touch Panel Analogue
Touch Sensitive Zone 1024 x 1024
Transmission Rate No
Type Of Cable No
Ue Rated Operational Voltage No
Ui Rated Insulation Voltage No
Uimp Rated Impulse Withstand No
[US] Rated Supply Voltage 24 V DC
Use Of Slot For 1 fieldbus communication card (Device Net, Profibus DP)
Vibration Resistance No
Voltage Drop On Power Supply F No
Voltage State1 Guaranteed No
Voltage State 0 Guaranteed No
Warranty Period 18 months
Analogue Input Type No
Current Consumption No
Depth 2.2 in (56 mm)
Discount Schedule MC2
Enclosure Material PPT
Encoding Type No
Filter Time No
Fuse Curve No
Fuse Size No
Height 9.41 in (239 mm)
Input Impedance No
Measurement Error No
Package Weight (Lbs) 9,3
Quantity Per Set No
Range Compatibility No
Range Of Product Magelis XBTGT
Reach Reference contains SVHC above the threshold  -  Go to CaP for more details
Realtime Clock Built-in
Relative Humidity Without condensation
Software Designation Vijeo Designer
Software Type Configuration software
Standards EN 61131-2FCC Class AIEC 61000-6-2UL 1604UL 508CSA C22.2 No 14
Supply External source
Sustainable Offer Status Green Premium product
Width 12.32 in (313 mm)
Wire Section No
