XBTGT4230
XBTGT4230
Share Send by e-mail advanced touchscreen panel - 640 x 480 pixels VGA - 7.5" - STN LCD - 24 V DC Support
Part Number xbtgt4230_xbt_gt
Accessory / Separate Part Category No
Accessory / Separate Part Designation No
Accessory / Separate Part Destination No
Accessory / Separate Part Type No
Ambient Air Temperature For Op 32...122 °F (0...50 °C)
Ambient Air Temperature For St -4...140 °F (-20...60 °C)
Brightness 8 levels via touch panel
Bus Type No
Cable Length No
Category Detail 22569 - MAGELIS XBT-GT (AND XBT-G)
Character Font ASCII (European characters)Chinese (simplified Chinese)Japanese (ANK, Kanji)KoreanTaiwanese (traditional Chinese)
Communication Port Protocol No
Communication Port Support No
Company Schneider Electric
Connector Type No
Contrast 8 levels via touch panel
Country Of Origin CN
Cut-Out Dimensions 204.5 (+ 1/- 0) x 159.5 (+ 1/- 0) mm
Display Colour 4096 colours
Display Resolution 640 x 480 pixels VGA
Display Size 7.5 inch
Display Type Backlit colour STN LCD
Downloadable Protocols FIPWAY Telemecanique ModiconModbus TCP Telemecanique ModiconModbus Plus Telemecanique ModiconThird party protocols Mitsubishi MelsecThird party protocols Rockwell Automation Allen-BradleyThird party protocols Siemens SimaticModbus Telemecanique ModiconThi
Electrical Connection No
Fixing Mode By 4 screw clampsBy 4 spring clips
GTIN 785901574866
Integrated Connection Type COM2 serial link RJ45 RS485
IP Degree Of Protection IP65 (front panel) conforming to IEC 60529IP20 (rear panel) conforming to IEC 60529
Kit Composition No
Local Signalling 1 LED (green or orange) normal operation or backlighting faulty
Marking CE
Memory Capacity No
Memory Description Back up of data SRAM 512 kB lithium battery
Memory Type 1 slot for Compact Flash card (128 MB to 1 GB)
Nbr. of units in pkg. 1
NEMA Degree Of Protection NEMA 4X front panel (indoor use)
Number Of Pages Limited by internal memory capacity
Operating System Magelis
Physical Interface No
Port Ethernet 10BASE-T/100BASE-TX
Power Consumption 28 W
Processor Frequency 266 MHz
Processor Name CPU RISC
Product Availability Stock - Normally stocked in distribution facility
Product Certifications ATEX zone 2/22CSA Class 1 Division 2 T4ACSA Class 1 Division 2 T5C-TickcULusUL Class 1 Division 2 T4AUL Class 1 Division 2 T5
Product Compatibility No
Product End Of Life Instructio Available
Product Life Status End of Commercialization
Product Mounting Flush mounting
Product Or Component Type Advanced touchscreen panel
Product Weight 3.97 lb(US) (1.8 kg)
Resistance To Electromagnetic 9.14 V/yd (10 V/m) conforming to IEC 61000-4-3
Resistance To Electrostatic Di 6 kV IEC 61000-4-2 level 3
Resistance To Fast Transients 2 kV conforming to IEC 61000-4-4 level 3
Returnability N
RoHS (date code: YYWW) Compliant  - since  0612  -  Schneider Electric declaration of conformity
Shock Resistance 15 gn 11 ms conforming to IEC 60068-2-27
Supply Voltage Limits 19.2...28.8 V
Touch Panel Analogue
Touch Sensitive Zone 1024 x 1024
[US] Rated Supply Voltage 24 V DC
Use Of Slot For 1 fieldbus communication card (Device Net, Profibus DP)
Warranty Period 18 months
Depth 2.36 in (60 mm)
Discount Schedule MC2
Enclosure Material PPT
Height 6.69 in (170 mm)
Package Weight (Lbs) 6,22
Quantity Per Set No
Range Compatibility No
Range Of Product Magelis XBTGT
Reach No
Realtime Clock Built-in
Relative Humidity Without condensation
Software Designation Vijeo Designer
Software Type Configuration software
Standards EN 61131-2FCC Class AIEC 61000-6-2UL 1604UL 508CSA C22.2 No 14
Supply External source
Sustainable Offer Status Green Premium product
Width 8.46 in (215 mm)
