VLM VLM2
VLM VLM2
With a design targeted for the most common servo motor features and offering torque ranges from 0.5N-m to almost 16 N-m, VLM delivers all the torque and performance of a servo while helping you control application costs.
 Features
NEMA 23 and 34 frame sizes
Metric 60 mm and 90 mm frame sizes
120/240 VAC, 160/320 VDC
Rated speeds up to 6,000 rpm
Up to 15.9 N-m peak, 4.5 N-m continuous
CE, UL, cUL
RoHS compliant
IP40 protection
1 m and 3 m lead lengths available
Standard cabling options for direct connection to AKD drives (resolver or encoder feedback)
Standard cabling options for direct connection to S200 (Hall feedback)
SFD Resolver Encoder
Options
Feedback devices: resolver, encoder, and Hall sensors
Shaft ends: keyway, flat, smooth
Molex, Firewire (Direct to S200-VTS), D-SUB (direct to AKD) and flying leads
Benefits
Best price for applications that do not require customization nor extra motor features
Exceptional quality and value
Standard motor sizes, windings and mounts to meet most application needs
Easy to use, with standard connector options and matching cables
Part Number vlm_vlm2
Stack Length 1,2,3
Windings C,E,D,G
Max BUS (VDC) 320
Max Stall Tc Nm (lb-in) 1.18 (10.4)
Max Tp Nm (lb-in) 4.2 (37.2)
Max Rated Speed (RPM) 6000
Max Rated Power @ Max BUS kW (Hp) .38 (.51)
Company Kollmorgen
