Stainless Steel W Series W-80x
The W Series offers Goldline® motor technology in a stainless steel housing with sealing technology that provides IP69K ingress protection for use in washdown environments. With a stainless steel shaft and connectors, plus food-grade bearing grease, these motors are ideal for food, beverage and pharmaceutical manufacturing applications that require frequent high-pressure cleaning to maintain the highest standards of hygiene.
Suitable for wet areas and high-pressure washdown applications
Stainless steel housing and shaft
Food-grade bearing grease
Round housing that resists accumulation of dirt
Sealed for IP69K ingress protection
1 - 79 N-m of continuous stall torque
Multiple feedback types
Optional holding brake
Mounts seamlessly with Micron® AquaTrue™ washdown planetary gearbox
Part Number stainless_steel_w_series_w-80x
Stack Length 2,4,6
Windings A,B
Max BUS (VDC) 320
Max Stall Tc Nm (lb-in) 217.01 (1921)
Max Tp Nm (lb-in) 322.80 (2857)
Max Rated N 2000
Max Rated Power @ Max BUS kW (Hp) 20.89 (28)
Company Kollmorgen
