SSBSM80C-475CA
SSBSM80C-475CA
30 lb. In. , SS BSM servo motor
Company Baldor
Part Number ssbsm80c_475ca
AMB. 25
Ambient Temperature 25 C
Base Indicator Bracket Mounted
Bearing Grease Type POLYREX EM
CLASS F
Constant stall current No
CUR CONT STALL/A RMS 5,32
Dimensional Drawing Numbers S2LYP263
Duty Rating CONT
Frame D100D
Frame Material Exposed Laminations
Frame Suffix D
Insulation Class F
IP Rating IP67
Max Speed 7,000 rpm
Max Speed Rpm 7000
Motor Lead Exit Front End
Motor Lead Quantity/Wire Size 3 @ 16 AWG
Multiplier Symbol E4
Nameplate Amps 5,32
Nameplate Output 1.76KW
Nameplate Speed 4000
Nameplate Voltage 300
Number of Poles 4
PEACK CUR/A RMS 13,6
Peak Current 13.6 A
Peak Torque 10.3 N-m
POWER 1.76KW
RATED BUS VOLTS 300
RATED SPEED/RPM 4000
Rated Torque 3.44 N-m
RoHS Status RoHS Compliant
Rotor Inertia (Servo) 0,00662
Shaft Diameter 0.785 in
Ship Weight 12 LB
SPEC. S2P263W049G1
Speed 4,000 rpm
Thermal Resistance No
Thermal Time Constant No
TORQ CONT STALL 3.44 NM
UPC 781568398760
