SSBSM80C-175CA
SSBSM80C-175CA
8 lb. In. , SS BSM servo motor
Company Baldor
Part Number ssbsm80c_175ca
AMB. 25
Ambient Temperature 25 C
Base Indicator Bracket Mounted
Bearing Grease Type POLYREX EM
CLASS F
Constant stall current 1.50 A
CUR CONT STALL/A RMS 1,54
Dimensional Drawing Numbers S2LYP263
Duty Rating CONT
Frame D100D
Frame Material Exposed Laminations
Frame Suffix D
Insulation Class F
IP Rating IP67
Max Speed 7,000 rpm
Max Speed Rpm 7000
Motor Lead Exit Front End
Motor Lead Quantity/Wire Size 3 @ 18 AWG
Multiplier Symbol E4
Nameplate Amps 1,54
Nameplate Output 0.26KW
Nameplate Speed 4000
Nameplate Voltage 300
Number of Poles 4
PEACK CUR/A RMS 3,93
Peak Current 3.9 A
Peak Torque 2.9 N-m
POWER 0.26KW
RATED BUS VOLTS 300
RATED SPEED/RPM 4000
Rated Torque 0.96 N-m
RoHS Status RoHS Compliant
Rotor Inertia (Servo) 0,00166
Shaft Diameter 0.748 in
Ship Weight 15 LB
SPEC. S2P263W050
Speed 4,000 rpm
Thermal Resistance No
Thermal Time Constant No
TORQ CONT STALL 0.96 NM
UPC 781568398814
