SSBSM63N-375CF
SSBSM63N-375CF
SSBSM63N-375CF TSTAT, ENCODER
Company Baldor
Part Number ssbsm63n_375cf
AMB. 25
Ambient Temperature 25 C
Base Indicator Bracket Mounted
Bearing Grease Type POLYREX EM
CLASS F
Constant stall current No
CUR CONT STALL/A RMS 2,82
Dimensional Drawing Numbers S1LYP178
Duty Rating CONT
Frame D75D
Frame Material Exposed Laminations
Frame Suffix D
Insulation Class F
IP Rating No
Max Speed 1,000 rpm
Max Speed Rpm 10000
Motor Lead Exit Front End
Motor Lead Quantity/Wire Size 3 @ 18 AWG
Multiplier Symbol E4
Nameplate Amps 2,82
Nameplate Output 0.64KW
Nameplate Speed 4000
Nameplate Voltage 300
Number of Poles 4
PEACK CUR/A RMS 10,2
Peak Current 10.2 A
Peak Torque 8.4 N-m
POWER 0.64KW
RATED BUS VOLTS 300
RATED SPEED/RPM 4000
Rated Torque 2.09 N-m
RoHS Status RoHS Compliant
Rotor Inertia (Servo) 0,0005
Shaft Diameter 0.433 in
Ship Weight 11 LB
SPEC. S1P178W035
Speed 4,000 rpm
Thermal Resistance No
Thermal Time Constant No
TORQ CONT STALL 2.09 NM
UPC 781568414088
