SSBSM50N-175CF
SSBSM50N-175CF
SSBSM50N-175CF TSTAT, ENCODER
Company Baldor
Part Number ssbsm50n_175cf
AMB. 25
Ambient Temperature 25 C
Base Indicator Bracket Mounted
Bearing Grease Type POLYREX EM
CLASS F
Constant stall current No
CUR CONT STALL/A RMS 0,79
Dimensional Drawing Numbers S5LYP138
Duty Rating CONT
Frame No
Frame Material Exposed Laminations
Frame Suffix D
Insulation Class F
IP Rating No
Max Speed 1,000 rpm
Max Speed Rpm 10000
Motor Lead Exit Front End
Motor Lead Quantity/Wire Size 3 @ 18 AWG
Multiplier Symbol E4
Nameplate Amps 0,79
Nameplate Output 0.19KW
Nameplate Speed 4000
Nameplate Voltage 300
Number of Poles 4
PEACK CUR/A RMS 2,52
Peak Current 2.5 A
Peak Torque 1.8 N-m
POWER 0.19KW
RATED BUS VOLTS 300
RATED SPEED/RPM 4000
Rated Torque 0.45 N-m
RoHS Status RoHS Compliant
Rotor Inertia (Servo) 0,00006
Shaft Diameter 0.355 in
Ship Weight 6 LB
SPEC. S5P138W025
Speed 4,000 rpm
Thermal Resistance 2.85C/WATT
Thermal Time Constant 700 min
TORQ CONT STALL 0.45 NM
UPC 781568414101
