SGMPH Sigma II Print
Rated Output: 100W, 200W, 400W, 750W, 1500W The SGMPH servomotor series has an internal permanent magnet (IPM) design which reduces rotor inertia. This servo motor is well suited for highly dynamic, high power applications such as hydraulic system replacement. There are 5 sizes from 22 kW to 55 kW providing up to 6,120 lb-in (700 Nm) of peak torque. 400 volt windings are available with rated speeds of 1,500 rpm and maximum speeds of 2,000 rpm. A 131,072 ppr incremental serial encoder is standard. Options include a 131,072 ppr absolute encoder, shaft seal, and holding brake.
Part Number SGMPH Sigma II Print
Time Rating Continuous
Vibration Class 15micrometer or less
Insulation Resistance 500 VDC, 10M Ohm min.
Ambient Temperature 0 to 40C
Excitation Permanent magnet
Mounting Flange-mounted
Withstand Voltage 1500 VAC for one minute
Enclosure Totally-enclosed, self cooled
Ambient Humidity 20% to 80% (no condensation)
Drive Method Direct drive
Rotation Direction Counterclockwise (CCW) with forward run reference when viewed from the load side
Thermal Class F
Company Yaskawa
