Precision Rolled 7820600
Screw only, No Ball nut;Our standard catalog ball screws feature a high luster polished and oiled finish, which provides, smoother operation, and a high quality look and feel.;Additional ball screw coatings (thin dense chrome, black oxide, manganese phosphate) are available as a custom item.;Screws must be machined to fit into end support bearings. Screws can be ordered with ends machined, assembled with ball nuts and/or support bearings.;Please submit a drawing or description for a quotation on a machined screw or screw and nut assembly. Ball Screw Only, Rolled Thread, Precision Style, 2.250 in X 0.500 in, RH, 0.004 in/ft Lead Accuracy, Steel, 1 Number of Starts, 240 in Long
Part Number 7820600_5bc88_06824214
Company Thomson Linear
Flange No
Load Lock No
Maximum Static Load No
Number Of Starts
Preload No
Return Style No
Rolled/Ground/Whirled Rolled Thread
Root Dia 1.85 in
[TH] No
Torque To Raise 1 Pound No
UPC Number No
Wiper No
Ball Bearing Diameter 0.375 in
Ball Bearing Quantity No
Diameter Major 2.23 in
Dynamic Load No
Length 240 in
Screw Diameter,Nominal 2.25 in
Standard Lead Accuracy ± 04 in/ft
Thread Direction RH
Travel Per Shaft Rev 0.5 in
