Precision Rolled 7820428
Screw only, No Ball nut;Our standard catalog ball screws feature a high luster polished and oiled finish, which provides, smoother operation, and a high quality look and feel.;Additional ball screw coatings (thin dense chrome, black oxide, manganese phosphate) are available as a custom item.;Screws must be machined to fit into end support bearings. Screws can be ordered with ends machined, assembled with ball nuts and/or support bearings.;Please submit a drawing or description for a quotation on a machined screw or screw and nut assembly. Ball Screw Only, Rolled Thread, Precision Style, 1.000 in X 0.250 in, LH, 0.004 in/ft Lead Accuracy, Steel, 1 Number of Starts, 192 in Long
Part Number 7820428_c3700_70904650
Company Thomson Linear
Flange No
Load Lock No
Maximum Static Load No
Number Of Starts
Preload No
Return Style No
Rolled/Ground/Whirled Rolled Thread
Root Dia 0.836 in
[TH] No
Torque To Raise 1 Pound No
UPC Number No
Wiper No
Ball Bearing Diameter 0.156 in
Ball Bearing Quantity No
Diameter Major 0.985 in
Dynamic Load No
Length 192 in
Screw Diameter,Nominal 1 in
Standard Lead Accuracy ± 04 in/ft
Thread Direction LH
Travel Per Shaft Rev 0.25 in
