Precision Rolled 190-9099
Screw only, No Ball nut;Our standard catalog ball screws feature a high luster polished and oiled finish, which provides, smoother operation, and a high quality look and feel.;Additional ball screw coatings (thin dense chrome, black oxide, manganese phosphate) are available as a custom item.;Screws must be machined to fit into end support bearings. Screws can be ordered with ends machined, assembled with ball nuts and/or support bearings.;Please submit a drawing or description for a quotation on a machined screw or screw and nut assembly. Ball Screw Only, Rolled Thread, Precision Style, RK0605, 0.631 in X 0.200 in, LH, 0.005 in/ft Lead Accuracy, Steel, 1 Number of Starts, 72 in Long
Part Number 190_9099_56109_91435092
Company Thomson Linear
Flange No
Load Lock No
Maximum Static Load No
Number Of Starts
Preload No
Return Style No
Rolled/Ground/Whirled Rolled Thread
Root Dia 0.503 in
[TH] No
Torque To Raise 1 Pound No
UPC Number 662486206712
Wiper No
Ball Bearing Diameter 0.125 in
Ball Bearing Quantity No
Diameter Major 0.61 in
Dynamic Load No
Length 72 in
Screw Diameter,Nominal 0.631 in
Standard Lead Accuracy ± 05 in/ft
Thread Direction LH
Travel Per Shaft Rev 0.2 in
