Precision Plus Ground 7820484
Part number is for a Nut and Screw assembly. Screw must be machined to fit end supports.;Preloaded, Round Ball Nut with Integral Flange and Wiper assembled to a screw;Long-lasting preload for minimal backlash and consistent stiffness;Screws must be machined to fit into end support bearings. Screws can be ordered with ends machined, assembled with support bearings. Please submit a drawing or description for a quotation on a machined screw assembly. Nut & Screw Assembly, Precision Plus Style, 2.250 in X 0.500 in, Preloaded, RH, .0005 in/ft Lead Accuracy, 120 in Long, 20160 lbf Dynamic Load
Company Thomson Linear
Part Number 7820484_a0486_22562653
[D1] 3.375 in
[D4] 4.375 in
[D5] 0.656 in
[D8] 5.375 in
[L] 8.125 in
[L1] 1.25 in
[L2] 0.812 in
[L3] 4.75 in
[L4] 2.259 in
[L5] 2.535 in
Maximum Static Load 108325 lbf
Preload Preloaded
Return Style Pickup Finger
Root Dia 1.858 in
Ball Bearing Diameter 0.375 in
Diameter Major 2.25 in
Dynamic Load 20160 lbf
Length 120 in
Screw Diameter,Nominal 2.25 in
Standard Lead Accuracy ± 005 in/ft
Thread Direction RH
Travel Per Shaft Rev 0.5 in
