Precision Plus Ground 7820483
Part number is for a Nut and Screw assembly. Screw must be machined to fit end supports.;Preloaded, Round Ball Nut with Integral Flange and Wiper assembled to a screw;Long-lasting preload for minimal backlash and consistent stiffness;Screws must be machined to fit into end support bearings. Screws can be ordered with ends machined, assembled with support bearings. Please submit a drawing or description for a quotation on a machined screw assembly. Nut & Screw Assembly, Precision Plus Style, 2.500 in X 0.250 in, Preloaded, RH, .0005 in/ft Lead Accuracy, 120 in Long, 8945 lbf Dynamic Load
Company Thomson Linear
Part Number 7820483_a4300_86188082
[D1] 3.375 in
[D4] 4 in
[D5] 0.344 in
[D8] 4.625 in
[L] 6.25 in
[L1] 0.75 in
[L2] 0.5 in
[L3] 4.75 in
[L4] 2.01 in
[L5] 2.609 in
Maximum Static Load 93165 lbf
Preload Preloaded
Return Style Pickup Finger
Root Dia 2.333 in
Ball Bearing Diameter 0.156 in
Diameter Major 2.5 in
Dynamic Load 8945 lbf
Length 120 in
Screw Diameter,Nominal 2.5 in
Standard Lead Accuracy ± 005 in/ft
Thread Direction RH
Travel Per Shaft Rev 0.25 in
