Precision Plus Ground 7820477
Part number is for a Nut and Screw assembly. Screw must be machined to fit end supports.;Preloaded, Round Ball Nut with Integral Flange and Wiper assembled to a screw;Long-lasting preload for minimal backlash and consistent stiffness;Screws must be machined to fit into end support bearings. Screws can be ordered with ends machined, assembled with support bearings. Please submit a drawing or description for a quotation on a machined screw assembly. Nut & Screw Assembly, Precision Plus Style, 1.000 in X 0.250 in, Preloaded, RH, .0005 in/ft Lead Accuracy, 72 in Long, 2285 lbf Dynamic Load
Company Thomson Linear
Part Number 7820477_81084_87029976
[D1] 1.685 in
[D4] 2.25 in
[D5] 0.344 in
[D8] 2.875 in
[L] 3.37 in
[L1] 0.5 in
[L2] 0.312 in
[L3] 3.75 in
[L4] 1.1 in
[L5] 1.203 in
Maximum Static Load 15815 lbf
Preload Preloaded
Return Style Pickup Finger
Root Dia 0.833 in
Ball Bearing Diameter 0.156 in
Diameter Major 1 in
Dynamic Load 2285 lbf
Length 72 in
Screw Diameter,Nominal 1 in
Standard Lead Accuracy ± 005 in/ft
Thread Direction RH
Travel Per Shaft Rev 0.25 in
