Precision Plus Ground 7820402
Part number is for a Nut and Screw assembly. Screw must be machined to fit end supports.;Preloaded, Round Ball Nut with Integral Flange and Wiper assembled to a screw;Long-lasting preload for minimal backlash and consistent stiffness;Screws must be machined to fit into end support bearings. Screws can be ordered with ends machined, assembled with support bearings. Please submit a drawing or description for a quotation on a machined screw assembly. Nut & Screw Assembly, Precision Plus Style, 2.000 in X 0.200 in, Preloaded, RH, .0005 in/ft Lead Accuracy, 120 in Long, 6181 lbf Dynamic Load
Company Thomson Linear
Part Number 7820402_a0481_97529908
[D1] 2.5 in
[D4] 3.25 in
[D5] 0.406 in
[D8] 4 in
[L] 5.75 in
[L1] 0.7 in
[L2] 0.438 in
[L3] 4.75 in
[L4] 1.55 in
[L5] 1.9 in
Maximum Static Load 65903 lbf
Preload Preloaded
Return Style Pickup Finger
Root Dia 1.849 in
Ball Bearing Diameter 0.141 in
Diameter Major 2 in
Dynamic Load 6181 lbf
Length 120 in
Screw Diameter,Nominal 2 in
Standard Lead Accuracy ± 005 in/ft
Thread Direction RH
Travel Per Shaft Rev 0.2 in
