Precision Plus Ground 7820401
Part number is for a Nut and Screw assembly. Screw must be machined to fit end supports.;Preloaded, Round Ball Nut with Integral Flange and Wiper assembled to a screw;Long-lasting preload for minimal backlash and consistent stiffness;Screws must be machined to fit into end support bearings. Screws can be ordered with ends machined, assembled with support bearings. Please submit a drawing or description for a quotation on a machined screw assembly. Nut & Screw Assembly, Precision Plus Style, 1.500 in X 0.500 in, Preloaded, RH, .0005 in/ft Lead Accuracy, 120 in Long, 5075 lbf Dynamic Load
Company Thomson Linear
Part Number 7820401_98781_14446937
[D1] 2.25 in
[D4] 3.125 in
[D5] 0.406 in
[D8] 3.875 in
[L] 4.625 in
[L1] 0.625 in
[L2] 0.41 in
[L3] 3.75 in
[L4] 1.575 in
[L5] 1.9 in
Maximum Static Load 35770 lbf
Preload Preloaded
Return Style Pickup Finger
Root Dia 1.236 in
Ball Bearing Diameter 0.25 in
Diameter Major 1.5 in
Dynamic Load 5075 lbf
Length 120 in
Screw Diameter,Nominal 1.5 in
Standard Lead Accuracy ± 005 in/ft
Thread Direction RH
Travel Per Shaft Rev 0.5 in
