Precision Plus Ground 7820396
Part number is for a Nut and Screw assembly. Screw must be machined to fit end supports.;Preloaded, Round Ball Nut with Integral Flange and Wiper assembled to a screw;Long-lasting preload for minimal backlash and consistent stiffness;Screws must be machined to fit into end support bearings. Screws can be ordered with ends machined, assembled with support bearings. Please submit a drawing or description for a quotation on a machined screw assembly. Nut & Screw Assembly, Precision Plus Style, 0.631 in X 0.200 in, Preloaded, RH, .0005 in/ft Lead Accuracy, 42 in Long, 440 lbf Dynamic Load
Company Thomson Linear
Part Number 7820396_71680_71856923
[D1] 1.13 in
[D4] 1.562 in
[D5] 0.281 in
[D8] 2 in
[L] 2.2 in
[L1] 0.375 in
[L2] 0.2 in
[L3] 2.75 in
[L4] 0.849 in
[L5] 0.71 in
Maximum Static Load 2110 lbf
Preload Preloaded
Return Style Pickup Finger
Root Dia 0.496 in
Ball Bearing Diameter 0.125 in
Diameter Major 0.611 in
Dynamic Load 440 lbf
Length 42 in
Screw Diameter,Nominal 0.631 in
Standard Lead Accuracy ± 005 in/ft
Thread Direction RH
Travel Per Shaft Rev 0.2 in
