Precision Plus Ground 5700979
Part number is for a Nut and Screw assembly. Screw must be machined to fit end supports.;Preloaded, Round Ball Nut with Integral Flange and Wiper assembled to a screw;Long-lasting preload for minimal backlash and consistent stiffness;Screws must be machined to fit into end support bearings. Screws can be ordered with ends machined, assembled with support bearings. Please submit a drawing or description for a quotation on a machined screw assembly. Nut & Screw Assembly, Precision Plus Style, 1.750 in X 0.200 in, Preloaded, RH, .0005 in/ft Lead Accuracy, 96 in Long, 4464 lbf Dynamic Load
Company Thomson Linear
Part Number 5700979_9c602_36002493
[D1] 2.265 in
[D4] 3.25 in
[D5] 0.406 in
[D8] 4 in
[L] 5 in
[L1] 0.625 in
[L2] 0.375 in
[L3] 4.75 in
[L4] 1.352 in
[L5] 1.878 in
Maximum Static Load 47446 lbf
Preload Preloaded
Return Style Pickup Finger
Root Dia 1.615 in
Ball Bearing Diameter 0.125 in
Diameter Major 1.75 in
Dynamic Load 4464 lbf
Length 96 in
Screw Diameter,Nominal 1.75 in
Standard Lead Accuracy ± 005 in/ft
Thread Direction RH
Travel Per Shaft Rev 0.2 in
