Precision Plus Ground 5700976
Part number is for a Nut and Screw assembly. Screw must be machined to fit end supports.;Preloaded, Round Ball Nut with Integral Flange and Wiper assembled to a screw;Long-lasting preload for minimal backlash and consistent stiffness;Screws must be machined to fit into end support bearings. Screws can be ordered with ends machined, assembled with support bearings. Please submit a drawing or description for a quotation on a machined screw assembly. Nut & Screw Assembly, Precision Plus Style, 1.150 in X 0.200 in, Preloaded, RH, .0005 in/ft Lead Accuracy, 72 in Long, 1680 lbf Dynamic Load
Company Thomson Linear
Part Number 5700976_84f08_44075308
[D1] 1.685 in
[D4] 2.28 in
[D5] 0.344 in
[D8] 2.875 in
[L] 3 in
[L1] 0.5 in
[L2] 0.312 in
[L3] 3.75 in
[L4] 1.067 in
[L5] 1.287 in
Maximum Static Load 14886 lbf
Preload Preloaded
Return Style Pickup Finger
Root Dia 1.015 in
Ball Bearing Diameter 0.125 in
Diameter Major 1.13 in
Dynamic Load 1680 lbf
Length 72 in
Screw Diameter,Nominal 1.15 in
Standard Lead Accuracy ± 005 in/ft
Thread Direction RH
Travel Per Shaft Rev 0.2 in
