PowerTrac SRT 4000 - 1000 RH
Inch Ball Screw, Standard Accuracy Rolled, SRT, 4.000" Ball Circle Diameter, 1.000" Lead, RH Thread
SRT – Standard Rolled Thread (sometimes referred to as commercial or transport type) ball screws offer the low friction advantage of antifriction screws at lower cost. They are capable of higher speeds and longer predictable life when compared to similar acme type lead screws.
SRT Ball Screws are manufactured from the same high quality materials and produced following the same ISO certified procedures as higher precision screws. Most SRT screws are rolled, induction heat treated and black oxide coated. Three sizes are also available in 17-4 PH stainless steel.
For convenience SRT screws can be supplied completely machined and assembled with nuts, flanges, wipers and EZZE-MOUNTS ready for assembly to your product. Should a standard assembly not fit the application, Nook can machine the screw to your specific design requirements.
Part Number powertrac_srt_4000_1000_rh
12 ft. Part Number SRT3261
16 ft. Part Number SRT0624
20 ft. Part Number SRT3262
2 ft. Part Number No
4 ft. Part Number SRT3259
6 ft. Part Number No
8 ft. Part Number SRT3260
Company Nook Industries
End Code for Type 4 [* Journals may show tracings of the thread] 48
End Code for Types 1,2,3,5 [* Journals may show tracings of the thread] 80
Lead Accuracy +/- [in./ft.] 0,008
Precision SRT
Screw Code 4000-1000 SRT RA
Screw Material 4150
Ball Circle Diameter [in] 4
Lead [in] 1
Root Diameter [in] 3,338
Screw Weight [lb./ft.] 34,4
Thread Direction RH
