PowerTrac SRT 1250 - 0200 LH
Inch Ball Screw, Standard Accuracy Rolled, SRT, 1.250" Ball Circle Diameter, 0.200" Lead, LH Thread
SRT – Standard Rolled Thread (sometimes referred to as commercial or transport type) ball screws offer the low friction advantage of antifriction screws at lower cost. They are capable of higher speeds and longer predictable life when compared to similar acme type lead screws.
SRT Ball Screws are manufactured from the same high quality materials and produced following the same ISO certified procedures as higher precision screws. Most SRT screws are rolled, induction heat treated and black oxide coated. Three sizes are also available in 17-4 PH stainless steel.
For convenience SRT screws can be supplied completely machined and assembled with nuts, flanges, wipers and EZZE-MOUNTS ready for assembly to your product. Should a standard assembly not fit the application, Nook can machine the screw to your specific design requirements.
Part Number powertrac_srt_1250_0200_lh
12 ft. Part Number SRT1221
16 ft. Part Number SRT1225
20 ft. Part Number No
2 ft. Part Number No
4 ft. Part Number SRT1223
6 ft. Part Number No
8 ft. Part Number SRT1227
Company Nook Industries
End Code for Type 4 [* Journals may show tracings of the thread] 16
End Code for Types 1,2,3,5 [* Journals may show tracings of the thread] 25
Lead Accuracy +/- [in./ft.] 0,004
Precision SRT
Screw Code 1250-0200 SRT LA
Screw Material 4150
Ball Circle Diameter [in] 1,25
Lead [in] 0,2
Root Diameter [in] 1,115
Screw Weight [lb./ft.] 3,7
Thread Direction LH
