PowerTrac SRT 1000 - 0250 RH Stainless Steel
Inch Ball Screw, Standard Accuracy Rolled, SRT, 1.000" Ball Circle Diameter, 0.250" Lead, RH Thread, Stainless Steel
SRT – Standard Rolled Thread (sometimes referred to as commercial or transport type) ball screws offer the low friction advantage of antifriction screws at lower cost. They are capable of higher speeds and longer predictable life when compared to similar acme type lead screws.
SRT Ball Screws are manufactured from the same high quality materials and produced following the same ISO certified procedures as higher precision screws. Most SRT screws are rolled, induction heat treated and black oxide coated. Three sizes are also available in 17-4 PH stainless steel.
For convenience SRT screws can be supplied completely machined and assembled with nuts, flanges, wipers and EZZE-MOUNTS ready for assembly to your product. Should a standard assembly not fit the application, Nook can machine the screw to your specific design requirements.
Part Number powertrac_srt_1000_0250_rh_s
12 ft. Part Number SRT6684
16 ft. Part Number No
20 ft. Part Number No
2 ft. Part Number No
4 ft. Part Number SRT6668
8 ft. Part Number SRT6676
Company Nook Industries
End Code for Type 4 [* Journals may show tracings of the thread] 12
End Code for Types 1,2,3,5 [* Journals may show tracings of the thread] 20
Lead Accuracy +/- [in./ft.] 0,004
Precision SRT
Screw Code 1000-0250 SRT RS
Screw Material 17-4 PH Stainless
Ball Circle Diameter [in] 1
Lead [in] 0,25
Root Diameter [in] 0,82
Screw Weight [lb./ft.] 2,2
Thread Direction RH
