PowerTrac SGT 1250 - 0200 RH/LH
Inch Twin-Lead Ball Screw, Precision Ground, SGT, 1.250" Ball Circle Diameter, 0.200" Lead, RH/LH Thread
Precision Twin-Lead ground ball screws offer dual opposing motion using a single drive system. These one-piece, high performance ball screws are made from high alloy steel that is black oxided for protection.
  • Lead accuracy of ±0.0005"/foot is standard
  • For a shorter unthreaded center section, contact Nook Industries customer service at 800-321-7800.
Precision Twin-lead ground screws are stocked for quick delivery without machined ends.
Part Number powertrac_sgt_1250_0200_rh_l
Company Nook Industries
End Code for Type 4 [* Journals may show tracings of the thread] 16
End Code for Types 1,2,3,5 [* Journals may show tracings of the thread] 25
Incomplete Overlapping Thread Length [in] 02.50
Lead Accuracy +/- [in./ft.] 0,001
Maximum Overall Length [in] 108
Maximum Useable LH & RH Thread [in] 52,75
Precision SGT
Screw Code 1250-0200 SGT TA
Screw Material 4150
Ball Circle Diameter [in] 1,25
Lead [in] 0,2
Root Diameter [in] 1,115
Screw Weight [lb./ft.] 3,7
Thread Direction RH/LH
