PowerTrac SGT 1000 - 0200 RH
Inch Ball Screw, Precision Ground, SGT, 1.000" Ball Circle Diameter, 0.200" Lead, RH Thread
SGT – Standard Ground Threads are ground from high carbon alloy steel that has been induction heat treated to a depth greater than the thread. Standard stocked screws have a lead accuracy tolerance of ±0.0005 in/ft and are supplied with internally preloaded nuts which must be factory assembled. Ground screws are used for applications that require smooth operation, precise positioning, and repeatability.
For convenience, SGT screws can be supplied completely machined and assembled with nuts and EZZE-MOUNTS ready for assembly. Should a standard assembly not fit the application, Nook can machine the screw to your specific design requirements. Ball nut configurations can be engineered to application requirements.
Part Number sgt_1000_0200_rh
4 ft. Part Number No
6 ft. Part Number GT10020R72
8 ft. Part Number No
Company Nook Industries
End Code for Type 4 [* Journals may show tracings of the thread] 12
End Code for Types 1,2,3,5 [* Journals may show tracings of the thread] 20
Lead Accuracy +/- [in./ft.] 0,0005
Precision SGT
Screw Code 1000-0200 SGT RA
Screw Material 4150
12 ft. Part Number No
Ball Circle Diameter [in] 1
Lead [in] 0,2
Root Diameter [in] 0,865
Screw Weight [lb./ft.] 2,2
Thread Direction RH
