PowerTrac SGN 0631 - 0200 RH
Inch Ball Nut, for SGT and XPR, Ground Accuracy, No Preload, SGN, 0.631" Ball Circle Diameter, 0.200" Lead, RH Thread
Part Number sgn_0631_0200_rh
Ball Nut Number SGN10083
Company Nook Industries
Dynamic Load [lb] 700
Flange Part Number FLG7570
Maximum Adjustable Preload [lb] No
Nominal Ball Diameter [in] 0,125
Nut Weight [lb] 0,8
Spring Rate x 106 [lb./in.] No
Static Load [lb] 3360
Torque to Raise 1 lb. [in-lb] 0,035
Wiper Kit Part Number -0
Ball Circle Diameter [in] 0,631
Lead [in] 0,2
Root Diameter [in] 0,5
Thread Direction RH
