PowerTrac PRN 1500 - 0500 RH, Prealoaded, XPR Only
Inch Ball Nut, for XPR, Ground Accuracy, Preloaded, Fixed, PRN, 1.500" Ball Circle Diameter, 0.500" Lead, RH Thread
Part Number prn_1500_0500_rh_prealoa
Ball Nut Number PRN10114
Company Nook Industries
Dynamic Load [lb] 5650
Flange Part Number -0
Maximum Adjustable Preload [lb] No
Nominal Ball Diameter [in] 0,312
Nut Weight [lb] 3,5
Spring Rate x 106 [lb./in.] 5,2
Static Load [lb] 35522
Torque to Raise 1 lb. [in-lb] 0,088
Wiper Kit Part Number ELASTOMER
Ball Circle Diameter [in] 1,5
Lead [in] 0,5
Root Diameter [in] 0,5
Thread Direction RH
