PowerTrac PRN 1000 - 0250 RH, Preloaded, WithOut Wipers, SGT Only
Inch Ball Nut, for SGT, Ground Accuracy, Preloaded, Fixed, PRN, 1.000" Ball Circle Diameter, 0.250" Lead, RH Thread, Without Wipers
Part Number prn_1000_0250_rh_withou
Ball Nut Number PGN11172
Company Nook Industries
Dynamic Load [lb] 2285
Flange Part Number FLG7571
Maximum Adjustable Preload [lb] No
Nominal Ball Diameter [in] 0,156
Nut Weight [lb] 1,5
Spring Rate x 106 [lb./in.] 2,5
Static Load [lb] 15815
Torque to Raise 1 lb. [in-lb] 0,044
Wiper Kit Part Number -0
Ball Circle Diameter [in] 1
Lead [in] 0,25
Root Diameter [in] 0,5
Thread Direction RH
