PowerTrac PRN 0631 - 0200 RH, Preloaded, With Wipers
Inch Ball Nut, for SGT and XPR, Ground Accuracy, Preloaded, Fixed, PRN, 0.631" Ball Circle Diameter, 0.200" Lead, RH Thread, With Wipers
Part Number prn_0631_0200_rh_with_w
Ball Nut Number PRN10108
Company Nook Industries
Dynamic Load [lb] 440
Flange Part Number FLG7555
Maximum Adjustable Preload [lb] No
Nominal Ball Diameter [in] 0,125
Nut Weight [lb] 0,98
Spring Rate x 106 [lb./in.] 1,6
Static Load [lb] 2110
Torque to Raise 1 lb. [in-lb] 0,035
Wiper Kit Part Number ELASTOMER
Ball Circle Diameter [in] 0,631
Lead [in] 0,2
Root Diameter [in] 0,5
Thread Direction RH
