PowerTrac 6000 1000 SRT RA, with SBN Ball Nut, Internal Return, Flanged
Inch Ball Screw AssemblyStandard Accuracy Rolled Inch Ball Screw, SRT, 6.000" Ball Circle Diameter, 1.000" Lead, RH Thread, Inch Ball Nut, for SRT, Standard Accuracy, No Preload, SBN, Standard, Integral Flange
Nook ball screw and nut assemblies provide ease of application, as all that is required is installation. Nook assemblies offer turn key solutions that only require a power source (hand operation or motor). All of the elements are available for quick delivery from shelf stock.
Part Number 60001000srtra_sbnint_flanged58
12 ft. Part Number No
16 ft. Part Number No
20 ft. Part Number No
4 ft. Part Number No
8 ft. Part Number No
Ball Nut Number SBN10442
Company Nook Industries
Dynamic Load [lb] 115507
End Code for Type 4 [* Journals may show tracings of the thread] n/a
End Code for Types 1,2,3,5 [* Journals may show tracings of the thread] n/a
Flange Part Number INTEGRAL
Lead Accuracy +/- [in./ft.] 0,002
Maximum Adjustable Preload [lb] No
Nominal Ball Diameter [in] 1,514
Nut Weight [lb] 225
Precision SRT
Screw Code 60001000 SRT RA
Screw Material 4150
Static Load [lb] 443548
Torque to Raise 1 lb. [in-lb] 0,177
Wiper Kit Part Number PLASTIC
Ball Circle Diameter [in] 6
Lead [in] 1
Root Diameter [in] 5,232
Screw Weight [lb./ft.] 34,4
Thread Direction RH
