PowerTrac 4000 1000 SRT RA, with SBN Ball Nut, Triple Circuit
Inch Ball Screw AssemblyStandard Accuracy Rolled Inch Ball Screw, SRT, 4.000" Ball Circle Diameter, 1.000" Lead, RH Thread, Inch Ball Nut, for SRT, Standard Accuracy, No Preload, SBN, Standard, Triple Circuit
Nook ball screw and nut assemblies provide ease of application, as all that is required is installation. Nook assemblies offer turn key solutions that only require a power source (hand operation or motor). All of the elements are available for quick delivery from shelf stock.
Part Number 40001000srtra_sbntriple58b93f0
12 ft. Part Number SRT3261
16 ft. Part Number SRT0624
20 ft. Part Number SRT3262
2 ft. Part Number No
4 ft. Part Number SRT3259
6 ft. Part Number No
8 ft. Part Number SRT3260
Ball Nut Number SBN3258
Company Nook Industries
Dynamic Load [lb] 85758
End Code for Type 4 [* Journals may show tracings of the thread] 48
End Code for Types 1,2,3,5 [* Journals may show tracings of the thread] 80
Flange Part Number FLG3307
Lead Accuracy +/- [in./ft.] 0,008
Maximum Adjustable Preload [lb] No
Nominal Ball Diameter [in] 0,625
Nut Weight [lb] 53,5
Precision SRT
Screw Code 40001000 SRT RA
Screw Material 4150
Static Load [lb] 476970
Torque to Raise 1 lb. [in-lb] 0,177
Wiper Kit Part Number WKB3306
Ball Circle Diameter [in] 4
Lead [in] 1
Root Diameter [in] 3,338
Screw Weight [lb./ft.] 34,4
Thread Direction RH
