PowerTrac 3000 1500 SRT RA, with SBN Ball Nut, Double Circuit
Inch Ball Screw AssemblyStandard Accuracy Rolled Inch Ball Screw, SRT, 3.000" Ball Circle Diameter, 1.500" Lead, RH Thread, Inch Ball Nut, for SRT, Standard Accuracy, No Preload, SBN, Standard, Double Circuit
Nook ball screw and nut assemblies provide ease of application, as all that is required is installation. Nook assemblies offer turn key solutions that only require a power source (hand operation or motor). All of the elements are available for quick delivery from shelf stock.
Part Number 30001500srtra_sbndouble58b93f0
12 ft. Part Number SRT4989
16 ft. Part Number SRT0444
20 ft. Part Number SRT0609
2 ft. Part Number No
4 ft. Part Number SRT4987
6 ft. Part Number No
8 ft. Part Number SRT4988
Ball Nut Number SBN4986
Company Nook Industries
Dynamic Load [lb] 53646
End Code for Type 4 [* Journals may show tracings of the thread] 39
End Code for Types 1,2,3,5 [* Journals may show tracings of the thread] 60
Flange Part Number FLG7575
Lead Accuracy +/- [in./ft.] 0,008
Maximum Adjustable Preload [lb] No
Nominal Ball Diameter [in] 0,5
Nut Weight [lb] 27,2
Precision SRT
Screw Code 30001500 SRT RA
Screw Material 4150
Static Load [lb] 253617
Torque to Raise 1 lb. [in-lb] 0,266
Wiper Kit Part Number WKB2661
Ball Circle Diameter [in] 3
Lead [in] 1,5
Root Diameter [in] 2,48
Screw Weight [lb./ft.] 19,3
Thread Direction RH
