PowerTrac 3000 - 0660 SRT TA, with SBN Ball Nuts, Triple Circuit
Inch Twin-Lead Ball Screw Assembly, Standard Accuracy Rolled, SRT, 3.000" Ball Circle Diameter, 0.660" Lead, RH/LH Thread, No Preload, SBN, Triple Circuit
Twin-Lead ball screw assemblies can be assembled with Nook, PowerTrac™ ball nuts, flanges and EZZE-MOUNT™ bearing supports to form cost effective systems. Twin-lead ball screws can be used in molding machines, packaging equipment, food processing machinery, robotics, material handling equipment, tire manufacturing and assembly applications.
Part Number 3000_0660_sbn_triple
A [In] No
Ball Nut Number SBN10202
Company Nook Industries
Dynamic Load [lb] 44316
End Code for Type 4 [* Journals may show tracings of the thread] 39
End Code for Types 1,2,3,5 [* Journals may show tracings of the thread] 30
Flange Part Number FLG7575
Incomplete Overlapping Thread Length [in] 06
Lead Accuracy +/- [in./ft.] 0,008
Maximum Adjustable Preload [lb] No
Maximum Overall Length [in] 192
Maximum Useable LH & RH Thread [in] 93
Nominal Ball Diameter [in] 0,5
Nut Weight [lb] 26
Precision SRT
Screw Code 3000-0660 SRT TA
Screw Material 4150
Static Load [lb] 271733
Torque to Raise 1 lb. [in-lb] 0,117
Wiper Kit Felt Part Number WKF3891
Wiper Kit Part Number WKB2661
Ball Circle Diameter [in] 3
Lead [in] 0,66
Root Diameter [in] 2,48
Screw Weight [lb./ft.] 19,6
Thread Direction RH
