PowerTrac 3000 0660 SRT RA, with SBN Ball Nut, Triple Circuit
Inch Ball Screw AssemblyStandard Accuracy Rolled Inch Ball Screw, SRT, 3.000" Ball Circle Diameter, 0.660" Lead, RH Thread, Inch Ball Nut, for SRT, Standard Accuracy, No Preload, SBN, Standard, Triple Circuit
Nook ball screw and nut assemblies provide ease of application, as all that is required is installation. Nook assemblies offer turn key solutions that only require a power source (hand operation or motor). All of the elements are available for quick delivery from shelf stock.
Part Number 30000660srtra_sbntriple58b93f0
12 ft. Part Number SRT5087
16 ft. Part Number SRT0433
20 ft. Part Number SRT0607
2 ft. Part Number No
4 ft. Part Number SRT5073
6 ft. Part Number No
8 ft. Part Number SRT5080
Ball Nut Number SBN10202
Company Nook Industries
Dynamic Load [lb] 44316
End Code for Type 4 [* Journals may show tracings of the thread] 39
End Code for Types 1,2,3,5 [* Journals may show tracings of the thread] 60
Flange Part Number FLG7575
Lead Accuracy +/- [in./ft.] 0,008
Maximum Adjustable Preload [lb] No
Nominal Ball Diameter [in] 0,5
Nut Weight [lb] 26
Precision SRT
Screw Code 30000660 SRT RA
Screw Material 4150
Static Load [lb] 271733
Torque to Raise 1 lb. [in-lb] 0,117
Wiper Kit Part Number WKB2661
Ball Circle Diameter [in] 3
Lead [in] 0,66
Root Diameter [in] 2,48
Screw Weight [lb./ft.] 19,6
Thread Direction RH
