PowerTrac 2500 0500 SRT RA, with SBN Ball Nut, Double Circuit
Inch Ball Screw AssemblyStandard Accuracy Rolled Inch Ball Screw, SRT, 2.500" Ball Circle Diameter, 0.500" Lead, RH Thread, Inch Ball Nut, for SRT, Standard Accuracy, No Preload, SBN, Standard, Double Circuit
Nook ball screw and nut assemblies provide ease of application, as all that is required is installation. Nook assemblies offer turn key solutions that only require a power source (hand operation or motor). All of the elements are available for quick delivery from shelf stock.
Part Number 25000500srtra_sbndouble58b93f0
12 ft. Part Number SRT0407
16 ft. Part Number SRT0408
20 ft. Part Number SRT0409
2 ft. Part Number No
4 ft. Part Number SRT0405
6 ft. Part Number No
8 ft. Part Number SRT0406
Ball Nut Number SBN10316
Company Nook Industries
Dynamic Load [lb] 21200
End Code for Type 4 [* Journals may show tracings of the thread] 32
End Code for Types 1,2,3,5 [* Journals may show tracings of the thread] 50
Flange Part Number 70600
Lead Accuracy +/- [in./ft.] 0,004
Maximum Adjustable Preload [lb] No
Nominal Ball Diameter [in] 0,375
Nut Weight [lb] 12,7
Precision SRT
Screw Code 25000500 SRT RA
Screw Material 4150
Static Load [lb] 186000
Torque to Raise 1 lb. [in-lb] 0,088
Wiper Kit Part Number No
Ball Circle Diameter [in] 2,5
Lead [in] 0,5
Root Diameter [in] 2,116
Screw Weight [lb./ft.] 14
Thread Direction RH
