PowerTrac 2500 0250 SRT RA, with SAR Ball Nut, Adjustable Preloaded, Flanged
Inch Ball Screw AssemblyStandard Accuracy Rolled Inch Ball Screw, SRT, 2.500" Ball Circle Diameter, 0.250" Lead, RH Thread, Inch Ball Nut, for SRT, Standard Accuracy, Preloaded, Adjustable, SAR, Integral Flange
Nook ball screw and nut assemblies provide ease of application, as all that is required is installation. Nook assemblies offer turn key solutions that only require a power source (hand operation or motor). All of the elements are available for quick delivery from shelf stock.
Part Number 25000250srtra_saradjus_flanged
12 ft. Part Number SRT3257
16 ft. Part Number SRT0442
20 ft. Part Number SRT0606
2 ft. Part Number No
4 ft. Part Number SRT3255
6 ft. Part Number No
8 ft. Part Number SRT3256
Ball Nut Number SAR3242
Company Nook Industries
Dynamic Load [lb] 6315
End Code for Type 4 [* Journals may show tracings of the thread] 32
End Code for Types 1,2,3,5 [* Journals may show tracings of the thread] 50
Flange Part Number INTEGRAL
Lead Accuracy +/- [in./ft.] 0,004
Maximum Adjustable Preload [lb] 1895
Nominal Ball Diameter [in] 0,156
Nut Weight [lb] 9,9
Precision SRT
Screw Code 25000250 SRT RA
Screw Material 4150
Static Load [lb] 81938
Torque to Raise 1 lb. [in-lb] 0,044
Wiper Kit Part Number BRUSH
Ball Circle Diameter [in] 2,5
Lead [in] 0,25
Root Diameter [in] 2,32
Screw Weight [lb./ft.] 15,45
Thread Direction RH
