PowerTrac 2250 1000 SRT RA, with SBN Ball Nut, Double Circuit
Inch Ball Screw AssemblyStandard Accuracy Rolled Inch Ball Screw, SRT, 2.250" Ball Circle Diameter, 1.000" Lead, RH Thread, Inch Ball Nut, for SRT, Standard Accuracy, No Preload, SBN, Standard, Double Circuit
Nook ball screw and nut assemblies provide ease of application, as all that is required is installation. Nook assemblies offer turn key solutions that only require a power source (hand operation or motor). All of the elements are available for quick delivery from shelf stock.
Part Number 22501000srtra_sbndouble58b93f0
12 ft. Part Number SRT4558
16 ft. Part Number SRT0441
20 ft. Part Number SRT0604
2 ft. Part Number No
4 ft. Part Number SRT4556
6 ft. Part Number No
8 ft. Part Number SRT4557
Ball Nut Number SBN4555
Company Nook Industries
Dynamic Load [lb] 26538
End Code for Type 4 [* Journals may show tracings of the thread] 28
End Code for Types 1,2,3,5 [* Journals may show tracings of the thread] 45
Flange Part Number FLG7574
Lead Accuracy +/- [in./ft.] 0,004
Maximum Adjustable Preload [lb] No
Nominal Ball Diameter [in] 0,375
Nut Weight [lb] 9
Precision SRT
Screw Code 22501000 SRT RA
Screw Material 4150
Static Load [lb] 412660
Torque to Raise 1 lb. [in-lb] 0,177
Wiper Kit Part Number WKB2659
Ball Circle Diameter [in] 2,25
Lead [in] 1
Root Diameter [in] 1,85
Screw Weight [lb./ft.] 10,9
Thread Direction RH
