PowerTrac 2250 - 0500 SRT TA, with SBN Ball Nuts, Double Circuit, Integral Safety Thread
Inch Twin-Lead Ball Screw Assembly, Standard Accuracy Rolled, SRT, 2.250" Ball Circle Diameter, 0.500" Lead, RH/LH Thread, No Preload, SBN, Double Circuit, Integral Safety Thread
Twin-Lead ball screw assemblies can be assembled with Nook, PowerTrac™ ball nuts, flanges and EZZE-MOUNT™ bearing supports to form cost effective systems. Twin-lead ball screws can be used in molding machines, packaging equipment, food processing machinery, robotics, material handling equipment, tire manufacturing and assembly applications.
Part Number 2250_0500_sbn_double_i
A [In] 6,688
Ball Nut Number SBN10074
Company Nook Industries
Dynamic Load [lb] 21306
End Code for Type 4 [* Journals may show tracings of the thread] 28
End Code for Types 1,2,3,5 [* Journals may show tracings of the thread] 45
Flange Part Number FLG7574
Incomplete Overlapping Thread Length [in] 05
Lead Accuracy +/- [in./ft.] 0,004
Maximum Adjustable Preload [lb] No
Maximum Overall Length [in] 192
Maximum Useable LH & RH Thread [in] 93,5
Nominal Ball Diameter [in] 0,375
Nut Weight [lb] 9
Precision SRT
Screw Code 2250-0500 SRT TA
Screw Material 4150
Static Load [lb] 142660
Torque to Raise 1 lb. [in-lb] 0,088
Wiper Kit Felt Part Number No
Wiper Kit Part Number WKB2659
Ball Circle Diameter [in] 2,25
Lead [in] 0,5
Root Diameter [in] 1,85
Screw Weight [lb./ft.] 10,9
Thread Direction RH
