PowerTrac 2250 0500 SRT RA, with SBN Ball Nut, Double Circuit, Safety Thread
Inch Ball Screw AssemblyStandard Accuracy Rolled Inch Ball Screw, SRT, 2.250" Ball Circle Diameter, 0.500" Lead, RH Thread, Inch Ball Nut, for SRT, Standard Accuracy, No Preload, SBN, Standard, Double Circuit, Safety Thread
Nook ball screw and nut assemblies provide ease of application, as all that is required is installation. Nook assemblies offer turn key solutions that only require a power source (hand operation or motor). All of the elements are available for quick delivery from shelf stock.
Part Number 22500500srtra_sbndouble_safety
12 ft. Part Number SRT5067
16 ft. Part Number SRT0439
20 ft. Part Number SRT0600
2 ft. Part Number No
4 ft. Part Number SRT5051
6 ft. Part Number No
8 ft. Part Number SRT5059
Ball Nut Number SBN10629
Company Nook Industries
Dynamic Load [lb] 21306
End Code for Type 4 [* Journals may show tracings of the thread] 28
End Code for Types 1,2,3,5 [* Journals may show tracings of the thread] 45
Flange Part Number FLG7574
Lead Accuracy +/- [in./ft.] 0,004
Maximum Adjustable Preload [lb] No
Nominal Ball Diameter [in] 0,375
Nut Weight [lb] 9
Precision SRT
Screw Code 22500500 SRT RA
Screw Material 4150
Static Load [lb] 142660
Torque to Raise 1 lb. [in-lb] 0,088
Wiper Kit Part Number WKF3890
Ball Circle Diameter [in] 2,25
Lead [in] 0,5
Root Diameter [in] 1,85
Screw Weight [lb./ft.] 10,9
Thread Direction RH
