PowerTrac 2250 0500 SRT LA, with SBN Ball Nut, Double Circuit, Integral Safety Thread
Inch Ball Screw AssemblyStandard Accuracy Rolled Inch Ball Screw, SRT, 2.250" Ball Circle Diameter, 0.500" Lead, LH Thread, Inch Ball Nut, for SRT, Standard Accuracy, No Preload, SBN, Standard, Double Circuit, Integral Safety Thread
Nook ball screw and nut assemblies provide ease of application, as all that is required is installation. Nook assemblies offer turn key solutions that only require a power source (hand operation or motor). All of the elements are available for quick delivery from shelf stock.
Part Number 22500500srtla_sbndouble_integr
12 ft. Part Number SRT4003
16 ft. Part Number SRT0440
20 ft. Part Number SRT0602
2 ft. Part Number No
4 ft. Part Number SRT4001
6 ft. Part Number No
8 ft. Part Number SRT4002
Ball Nut Number SBN10075
Company Nook Industries
Dynamic Load [lb] 21306
End Code for Type 4 [* Journals may show tracings of the thread] 28
End Code for Types 1,2,3,5 [* Journals may show tracings of the thread] 45
Flange Part Number FLG7574
Lead Accuracy +/- [in./ft.] 0,004
Maximum Adjustable Preload [lb] No
Nominal Ball Diameter [in] 0,375
Nut Weight [lb] 9
Precision SRT
Screw Code 22500500 SRT LA
Screw Material 4150
Static Load [lb] 142660
Torque to Raise 1 lb. [in-lb] 0,088
Wiper Kit Part Number WKF0456
Ball Circle Diameter [in] 2,25
Lead [in] 0,5
Root Diameter [in] 1,85
Screw Weight [lb./ft.] 10,9
Thread Direction LH
