PowerTrac 2000 - 0200 SGT TA, with SSN Ball Nuts, Flanged
Inch Twin-Lead Ball Screw Assembly, Precision Ground , SGT, 2.000" Ball Circle Diameter, 0.200" Lead, RH/LH Thread, Preloaded, Fixed, Flanged, SSN
Precision Twin-Lead ground ball screw assemblies can be assembled with Nook, PowerTrac™ precision groung ball nuts, flanges and EZZE-MOUNT™ bearing supports to form cost effective systems. Precision Twin-lead ground ball screws can be used in molding machines, packaging equipment, food processing machinery, robotics, material handling equipment, tire manufacturing and assembly applications.
Part Number powertrac_2000_0200_sgt_ta
Ball Nut Number SSN0396
Company Nook Industries
Dynamic Load [lb] 6181
End Code for Type 4 [* Journals may show tracings of the thread] 28
End Code for Types 1,2,3,5 [* Journals may show tracings of the thread] 45
Flange Part Number INTEGRAL
Incomplete Overlapping Thread Length [in] 00.50
Lead Accuracy +/- [in./ft.] 0,001
Maximum Overall Length [in] 140
Maximum Useable LH & RH Thread [in] 69,75
Nominal Ball Diameter [in] 0,141
Nut Weight [lb] 4,5
Precision SGT
Screw Code 2000-0200 SGT TA
Screw Material 4150
Spring Rate x 106 [lb./in.] 6,5
Static Load [lb] 65903
Torque to Raise 1 lb. [in-lb] 0,035
Wiper Kit Part Number ELASTOMER
Ball Circle Diameter [in] 2
Lead [in] 0,2
Root Diameter [in] 1,849
Screw Weight [lb./ft.] 9,9
Thread Direction RH
