PowerTrac 1500 - 1000 SRT TA, with SBN Ball Nuts, Double Circuit
Inch Twin-Lead Ball Screw Assembly, Standard Accuracy Rolled, SRT, 1.500" Ball Circle Diameter, 1.000" Lead, RH/LH Thread, No Preload, SBN, Double Circuit
Twin-Lead ball screw assemblies can be assembled with Nook, PowerTrac™ ball nuts, flanges and EZZE-MOUNT™ bearing supports to form cost effective systems. Twin-lead ball screws can be used in molding machines, packaging equipment, food processing machinery, robotics, material handling equipment, tire manufacturing and assembly applications.
Part Number 1500_1000_sbn_double
A [In] No
Ball Nut Number SBN8280
Company Nook Industries
Dynamic Load [lb] 7560
End Code for Type 4 [* Journals may show tracings of the thread] 16
End Code for Types 1,2,3,5 [* Journals may show tracings of the thread] 25
Flange Part Number FLG7777
Incomplete Overlapping Thread Length [in] 04
Lead Accuracy +/- [in./ft.] 0,004
Maximum Adjustable Preload [lb] No
Maximum Overall Length [in] 192
Maximum Useable LH & RH Thread [in] 94
Nominal Ball Diameter [in] 0,344
Nut Weight [lb] 3,9
Precision SRT
Screw Code 1500-1000 SRT TA
Screw Material 4150
Static Load [lb] 34662
Torque to Raise 1 lb. [in-lb] 0,177
Wiper Kit Felt Part Number No
Wiper Kit Part Number WKB2657
Ball Circle Diameter [in] 1,5
Lead [in] 1
Root Diameter [in] 1,14
Screw Weight [lb./ft.] 4,47
Thread Direction RH
