PowerTrac 1500 1000 SRT RA, with SEL Ball Nut, Adjustable Preloaded
Inch Ball Screw AssemblyStandard Accuracy Rolled Inch Ball Screw, SRT, 1.500" Ball Circle Diameter, 1.000" Lead, RH Thread, Inch Ball Nut, for SRT, Standard Accuracy, Preloaded, Adjustable, SEL
Nook ball screw and nut assemblies provide ease of application, as all that is required is installation. Nook assemblies offer turn key solutions that only require a power source (hand operation or motor). All of the elements are available for quick delivery from shelf stock.
Part Number 15001000srtra_seladjus58b93f0c
12 ft. Part Number SRT8853
16 ft. Part Number SRT0436
20 ft. Part Number SRT0598
2 ft. Part Number No
4 ft. Part Number SRT8837
6 ft. Part Number No
8 ft. Part Number SRT8845
Ball Nut Number SEL0698
Company Nook Industries
Dynamic Load [lb] 7560
End Code for Type 4 [* Journals may show tracings of the thread] 16
End Code for Types 1,2,3,5 [* Journals may show tracings of the thread] 25
Flange Part Number FLG7777
Lead Accuracy +/- [in./ft.] 0,004
Maximum Adjustable Preload [lb] 1650
Nominal Ball Diameter [in] 0,344
Nut Weight [lb] 9,1
Precision SRT
Screw Code 15001000 SRT RA
Screw Material 4150
Static Load [lb] 34662
Torque to Raise 1 lb. [in-lb] 0,177
Wiper Kit Part Number WKB2657
Ball Circle Diameter [in] 1,5
Lead [in] 1
Root Diameter [in] 1,14
Screw Weight [lb./ft.] 4,47
Thread Direction RH
