PowerTrac 1500 1000 SRT LA, with SBN Ball Nut, Double Circuit
Inch Ball Screw AssemblyStandard Accuracy Rolled Inch Ball Screw, SRT, 1.500" Ball Circle Diameter, 1.000" Lead, LH Thread, Inch Ball Nut, for SRT, Standard Accuracy, No Preload, SBN, Standard, Double Circuit
Nook ball screw and nut assemblies provide ease of application, as all that is required is installation. Nook assemblies offer turn key solutions that only require a power source (hand operation or motor). All of the elements are available for quick delivery from shelf stock.
Part Number 15001000srtla_sbndouble58b93f0
12 ft. Part Number SRT2203
16 ft. Part Number SRT0437
20 ft. Part Number SRT0615
2 ft. Part Number No
4 ft. Part Number SRT1991
6 ft. Part Number No
8 ft. Part Number SRT1992
Ball Nut Number SBN1995
Company Nook Industries
Dynamic Load [lb] 7560
End Code for Type 4 [* Journals may show tracings of the thread] 16
End Code for Types 1,2,3,5 [* Journals may show tracings of the thread] 25
Flange Part Number FLG7777
Lead Accuracy +/- [in./ft.] 0,004
Maximum Adjustable Preload [lb] No
Nominal Ball Diameter [in] 0,344
Nut Weight [lb] 3,9
Precision SRT
Screw Code 15001000 SRT LA
Screw Material 4150
Static Load [lb] 34662
Torque to Raise 1 lb. [in-lb] 0,177
Wiper Kit Part Number WKB2657
Ball Circle Diameter [in] 1,5
Lead [in] 1
Root Diameter [in] 1,14
Screw Weight [lb./ft.] 4,47
Thread Direction LH
