PowerTrac 1500 0500 SRT RA, with SBN Ball Nut, Double Circuit, Integral Safety Thread
Inch Ball Screw AssemblyStandard Accuracy Rolled Inch Ball Screw, SRT, 1.500" Ball Circle Diameter, 0.500" Lead, RH Thread, Inch Ball Nut, for SRT, Standard Accuracy, No Preload, SBN, Standard, Double Circuit, Integral Safety Thread
Nook ball screw and nut assemblies provide ease of application, as all that is required is installation. Nook assemblies offer turn key solutions that only require a power source (hand operation or motor). All of the elements are available for quick delivery from shelf stock.
Part Number 15000500srtra_sbndouble_integr
12 ft. Part Number SRT9996
16 ft. Part Number SRT9997
20 ft. Part Number SRT9998
2 ft. Part Number No
4 ft. Part Number SRT9994
6 ft. Part Number No
8 ft. Part Number SRT9995
Ball Nut Number SBN10974
Company Nook Industries
Dynamic Load [lb] 12320
End Code for Type 4 [* Journals may show tracings of the thread] 16
End Code for Types 1,2,3,5 [* Journals may show tracings of the thread] 25
Flange Part Number FLG10060
Lead Accuracy +/- [in./ft.] 0,004
Maximum Adjustable Preload [lb] No
Nominal Ball Diameter [in] 0,312
Nut Weight [lb] 5,2
Precision SRT
Screw Code 15000500 SRT RA
Screw Material 4150
Static Load [lb] 97696
Torque to Raise 1 lb. [in-lb] 0,088
Wiper Kit Part Number BRUSH
Ball Circle Diameter [in] 1,5
Lead [in] 0,5
Root Diameter [in] 1,174
Screw Weight [lb./ft.] 5,25
Thread Direction RH
