PowerTrac 1500 0473 SRT RA, with SBN Ball Nut, Keyed, Double Circuit
Inch Ball Screw AssemblyStandard Accuracy Rolled Inch Ball Screw, SRT, 1.500" Ball Circle Diameter, 0.473" Lead, RH Thread, Inch Ball Nut, for SRT, Standard Accuracy, No Preload, SBN, Keyed, Double Circuit
Nook ball screw and nut assemblies provide ease of application, as all that is required is installation. Nook assemblies offer turn key solutions that only require a power source (hand operation or motor). All of the elements are available for quick delivery from shelf stock.
Part Number 15000473srtra_sbnkeyed_double5
12 ft. Part Number SRT9624
16 ft. Part Number SRT0435
20 ft. Part Number SRT0597
2 ft. Part Number No
4 ft. Part Number SRT9610
6 ft. Part Number No
8 ft. Part Number SRT9127
Ball Nut Number SBN8345
Company Nook Industries
Dynamic Load [lb] 10050
End Code for Type 4 [* Journals may show tracings of the thread] 16
End Code for Types 1,2,3,5 [* Journals may show tracings of the thread] 25
Flange Part Number No
Lead Accuracy +/- [in./ft.] 0,004
Maximum Adjustable Preload [lb] No
Nominal Ball Diameter [in] 0,344
Nut Weight [lb] 3,9
Precision SRT
Screw Code 15000473 SRT RA
Screw Material 4150
Static Load [lb] 57770
Torque to Raise 1 lb. [in-lb] 0,084
Wiper Kit Part Number WKB2656
Ball Circle Diameter [in] 1,5
Lead [in] 0,473
Root Diameter [in] 1,14
Screw Weight [lb./ft.] 4,47
Thread Direction RH
