PowerTrac 1500 - 0250 SRT TA, with SBN Ball Nuts, Double Circuit
Inch Twin-Lead Ball Screw Assembly, Standard Accuracy Rolled, SRT, 1.500" Ball Circle Diameter, 0.250" Lead, RH/LH Thread, No Preload, SBN, Double Circuit
Twin-Lead ball screw assemblies can be assembled with Nook, PowerTrac™ ball nuts, flanges and EZZE-MOUNT™ bearing supports to form cost effective systems. Twin-lead ball screws can be used in molding machines, packaging equipment, food processing machinery, robotics, material handling equipment, tire manufacturing and assembly applications.
Part Number 1500_0250_sbn_double
A [In] No
Ball Nut Number SBN9587
Company Nook Industries
Dynamic Load [lb] 4198
End Code for Type 4 [* Journals may show tracings of the thread] 19
End Code for Types 1,2,3,5 [* Journals may show tracings of the thread] 30
Flange Part Number FLG6754
Incomplete Overlapping Thread Length [in] 03
Lead Accuracy +/- [in./ft.] 0,004
Maximum Adjustable Preload [lb] No
Maximum Overall Length [in] 108
Maximum Useable LH & RH Thread [in] 52,5
Nominal Ball Diameter [in] 0,156
Nut Weight [lb] 1,7
Precision SRT
Screw Code 1500-0250 SRT TA
Screw Material 4150
Static Load [lb] 44030
Torque to Raise 1 lb. [in-lb] 0,044
Wiper Kit Felt Part Number No
Wiper Kit Part Number WKB2654
Ball Circle Diameter [in] 1,5
Lead [in] 0,25
Root Diameter [in] 1,32
Screw Weight [lb./ft.] 5,16
Thread Direction RH
