PowerTrac 1500 0250 SRT RA, with SAR Ball Nut, Adjustable Preloaded, Flanged
Inch Ball Screw AssemblyStandard Accuracy Rolled Inch Ball Screw, SRT, 1.500" Ball Circle Diameter, 0.250" Lead, RH Thread, Inch Ball Nut, for SRT, Standard Accuracy, Preloaded, Adjustable, SAR, Flanged
Nook ball screw and nut assemblies provide ease of application, as all that is required is installation. Nook assemblies offer turn key solutions that only require a power source (hand operation or motor). All of the elements are available for quick delivery from shelf stock.
Part Number 15000250srtra_saradjus_flanged
12 ft. Part Number SRT7028
16 ft. Part Number SRT0433
20 ft. Part Number SRT0595
2 ft. Part Number No
4 ft. Part Number SRT7012
6 ft. Part Number No
8 ft. Part Number SRT7020
Ball Nut Number SAR3043
Company Nook Industries
Dynamic Load [lb] 4198
End Code for Type 4 [* Journals may show tracings of the thread] 19
End Code for Types 1,2,3,5 [* Journals may show tracings of the thread] 30
Flange Part Number INTEGRAL
Lead Accuracy +/- [in./ft.] 0,004
Maximum Adjustable Preload [lb] 920
Nominal Ball Diameter [in] 0,156
Nut Weight [lb] 6
Precision SRT
Screw Code 15000250 SRT RA
Screw Material 4150
Static Load [lb] 44030
Torque to Raise 1 lb. [in-lb] 0,044
Wiper Kit Part Number BRUSH
Ball Circle Diameter [in] 1,5
Lead [in] 0,25
Root Diameter [in] 1,32
Screw Weight [lb./ft.] 5,16
Thread Direction RH
