PowerTrac 1500 0250 SRT LA, with SEL Ball Nut, Adjustable Preloaded
Inch Ball Screw AssemblyStandard Accuracy Rolled Inch Ball Screw, SRT, 1.500" Ball Circle Diameter, 0.250" Lead, LH Thread, Inch Ball Nut, for SRT, Standard Accuracy, Preloaded, Adjustable, SEL
Nook ball screw and nut assemblies provide ease of application, as all that is required is installation. Nook assemblies offer turn key solutions that only require a power source (hand operation or motor). All of the elements are available for quick delivery from shelf stock.
Part Number 15000250srtla_seladjus58b93f0c
12 ft. Part Number SRT3254
16 ft. Part Number SRT0434
20 ft. Part Number SRT0596
2 ft. Part Number No
4 ft. Part Number SRT3252
6 ft. Part Number No
8 ft. Part Number SRT3253
Ball Nut Number SEL4573
Company Nook Industries
Dynamic Load [lb] 4198
End Code for Type 4 [* Journals may show tracings of the thread] 19
End Code for Types 1,2,3,5 [* Journals may show tracings of the thread] 30
Flange Part Number FLG6754
Lead Accuracy +/- [in./ft.] 0,004
Maximum Adjustable Preload [lb] 920
Nominal Ball Diameter [in] 0,156
Nut Weight [lb] 3
Precision SRT
Screw Code 15000250 SRT LA
Screw Material 4150
Static Load [lb] 44030
Torque to Raise 1 lb. [in-lb] 0,044
Wiper Kit Part Number WKB2654
Ball Circle Diameter [in] 1,5
Lead [in] 0,25
Root Diameter [in] 1,32
Screw Weight [lb./ft.] 5,16
Thread Direction LH
